Hey I'm looking at putting some 6 by 9s in the parcel tray of my car and after much searching I believe I've found how to move the rear seat out of the way. but what i was wondering is are the rear speakers are 6 by 9? or if they are 6's? and then what am I going to need to do if I want to change them to 6 by 9's?
Cheers in advance guys!
https://www.sau.com.au/forums/topic/370595-r33-rear-speakers/
6x9's wont fit unless you use a spacer type thing.
I only have 6x9s in mine because i had them. So got some black plastic spacers to lift them enough to fit.
Easiest option however is 6.5inches. They just dont have much nuts to them.
Right, so 6's is the general consensus? other than the installing problem im not to sure what the problems are with the 6x9s though? anyone then have some suggestions on the type of speakers to go for, is branding etc merely going to be personal preference
here is a few reasons they suck
1) Possible standing waves in the surround.
2) Non-even dispersion of sound wave across
radiating area
3) Standing waves IN the cone
4) Poorly controlled moving mass due to
unsymmetrical loading of suspension.
when you ask what brand 6 in to buy it depends on budget, tastes, brand loyalty and so much more , and if you have amp or factory deck etc to power them ?
and of course then if you don't install them right any speaker will sound horrible, or out of phase , no bass etc.
dont overlook some of the SAU sponsors or contributuors on here ?
yeah but what i meant was if the 2nd pic is a 6inch speaker - and he is saying that 6inches is the biggest that will fit the STANDARD speaker mounts - then why is there the piece of mdf? (sorry dont mean to argue such a small point, im doing my system soon - just wanting to confirm the sizes without having to cut/fabricate anything.. was told and have read they are 6.5 front and rear but possibly they arent?)
Im not sure what the issue with 6x9's is either.
When i had them in the parcel shelf of my ITR they sounded fantastic. Possibly because i did a good job installing them properly.
They sound like ass, and i knew they would, in the 33 because they dont fit. But it was a remedy to have sound, rather than broken speakers.
Sweet went for the 6" got some nice clean crisp sound going on, next step bass =]
I'm running 6.5" component speakers in the front powered by an amp with the rears faded and found the sq and bass was good enough not to require 6x9's or a sub
Whats "sq" sorry? but yer might give that a go first and then if i feel the need to add more i can go from there
  • 2 months later...
Ha well im semi afraid to say I went with the 6x9's but they have worked out well, got an 800w amp powering them and the 6's up front and they sound great and crisp also got a 10" sub powered by just a 222W amp at the moment which goes well but lacks the power at louder volume so upping the amp for that soon
Oh and also just heads up for others, I wired mine so that my front and rear speakers are playing off the front RCA port and the sub is off the Rear RCA port in the headunit. means I dont have a difference between front and rear sound at the moment, but means when I fade all the way to the rear I just get the sub, neat little trick :P will probably end up wiring it back so that front and back are in their respective ports and split the rear port for the sub also
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
