For sale:
1 x R32 Steering Wheel (good condition) - $100 firm
1 x old Momo race steering wheel (very good condition) - looks as new, leather is in top condition - offers around $100
1 x RAZO turbo timer - $50
1 x US AMP (2 Channel 500WRMS if I remember correctly) - $200
Sony Xplod 6x9 - $50
2 x black SAU snap on seat covers - $50 firm
In Sydney.
hey im interested in the momo race steering wheel.
do u have a pic? if not where abt in syd u located. i can drop by n take a look and if i like it i buy it
For sale:
In Sydney.
Riverside - go here: http://www.skylinesaustralia.com/forums/sh...ead.php?t=35931
they're the same but in black (white print). yes they are slip on
I'll try and get pics soon (no easy access to digi cam).
no boss kit - sorry guys.
bump.
also got 60mm black Autometer boost gauge
white Autometer AFR (not 60mm)
make an offer. I also have 2 purple Spitfire gauge holders (free with the gauges).
I'll try get some pics
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
