Item Summary: Nissan 180sx Very modified, great fun
Condition: Used
Reason for Selling: Pretty sure i've done the turbo a mischief and cant be bothered fixing it. It ran unlimited boost after blowing the bleed valves top off and began making a whirring noise on spool up.
Asking Price: 7500
Delivery Methods: PickUp
Contact Info:
Extra Information:
LOCATED IN VIC
PRICE DROP 7,500
Engine
Shot piened rods and pistons
Performance rings
Balanced block
Head work
Billet crank
Kevlar timing belt
550cc injectors
HKS Cams
HKS Cam gears
HKS Silicon hoses
HKS Duel dump pipe
GFB BOV
Engine resprayed candy apple red
Intake
Z32 AFM
R33 radiator
Big cooler
Thermo fans
Stainless induction
Powder coated black cooler pipes
Driveline
Lightened fly wheel
2 way mechanical LSD (Cusco I think)
Fully adjustable JIC Gold coilovers
Exhaust
3" stainless exhaust
Interior gadgets
HKS incab duel stage boost control
HKS Turbo timer
HKS Boost gauge
HKS Stainless shifter
Momo steering wheel
Recaro adjustable back race seat
HUD (speedo on windscreen)
Black wired alarm
Keyless entry
Electric windows
Full stereo including sub and amp
Origional 180sx floor mats
ECU
Dr Drift tuned ECU
Suspension etc
Strut brace
Nolathane bushes etc
P1 Buddy light weight race rims
Upgraded cross drilled disks
Upgraded callipers
Pads need a change
Body
Car resprayed Polar White
C-West front bar
Buddy club side skirts (I think)
Vertex rear bar (I think)
Shaved rear wing
Type x tail light and centre
Vented bonnet
If you'd like any info just ask.
The car puts out close to 250rwkw on an aggresive tune, I drive it around at 170rwkw because it's just used to get me too and from work.
https://www.sau.com.au/forums/topic/370776-180sx/
  • 2 months later...
Hey mate, I'm a bit confused about your add. Is this car in perfect working order or what's wrong with it? Only thing that's thrown me is your reason for sale?
Sorry i just copy and pasted the add without looking at it.
As far as i know the turbo seal is knackered, i cant be 100% tho because im not a mechanic. The turbo started making noise on boost so i garaged it and havnt started it since as i have a daily driver and am a little over the modifying scene. Reason for selling is exactly that, i dont know what's wrong and cant be buggered playing around anymore. My shed at the moment isnt the best for pulling a car apart so i'd rather it go to some one who has the time to play around with it.
The car was absolutely amazing value when i had it going but it kills me seeing it sitting there idle knowing that some one else could be having fun with it so its time to send it off
https://www.sau.com.au/forums/topic/370776-180sx/#findComment-6052560
Im located in Ballarat, about an hour from melb.
And no i havnt researched how much to fix the turbo, presuming it is the turbo thats buggered. Im not a mechanic and cant be buggered putting any more time into it, as previously said i have a daily and am not as much into the scene as i used to be. It's time for it to go to a new home.
https://www.sau.com.au/forums/topic/370776-180sx/#findComment-6054241
So hard to sell a car!!!
without being rude mate its because you are asking $7500 for a car that doesn't work, has no rego, no rwc, and you cant even be certain what is actually wrong with it.
https://www.sau.com.au/forums/topic/370776-180sx/#findComment-6079913
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
