  • Replies 44
the rb20 will probably drive all around australia twice on the redline the entire way without blowing lol. I think most motorbikes have a longer stroke haha
still, hopefully they are dumb enough to keep driving it and they catch them.
Edited by Rolls
hey look if u blokes really need help go see john at marvey tech(family) and tel him jeturbo the homo sent ya and he will fit an alarm /imobiliser at a very good rate and will be the latest and greatest blackwire jobbie and then ya cars wont go anywhere unless they really want it and tow the beast pinch.gif
lets not forget a coupla hundred bucks now saves the poor young bloke recieving a call to collect his burnt out wreck :thumbsup:
Import_zone on hardtuned wrote in their spotted thread that he had seen a purple 32 yesterday in the hills and has spoken to police. He/she wanted someone on sau to pass on the message. Hope the car is recovered mate!
What id like to know is how come we all seem to not be able to pull out the driveway without being pulled over for a defect, yet these criminals can drive around numerous times using the stolen cars to steal more imports...and not get pulled over?
Am I missing something other than a balaclava, set of screwdrivers and some tool kit to keep in the car that guarantees to not get noticed by the local on duty?
Cant answer that, but I can say from my own experience that I've been pulled over twice in the 4 years of owning my GTR and using it as a daily driver.
On both occasions it was a bretho and licence check, and I was sent on my way without incident.
I suppose upkeep, keeping it stock and not driving like a tool are the 3 things that have helped me, however I do worry like everyone else, especially since my exhaust is loudish...
-D
I can agree with you there dohmar. My silver paint helps but when your car and driving style doesn't scream 'street racer' you don't have much to worry about. I've never been pulled over in a year of GTR ownership and daily driving.
Ive used my car as a daily in the past, and the last time I was defected the cop was pulling out of a side street as I was coming past in the front of a pack of traffic. The cop basically raced, weaved and then stuck his lights on behind others to get to me specifically. Once he looked over my car, even commenting on how clean and standard it was, chose to defect me for less than 5mm too low. I wasnt driving like a moron, nor do I have any large bling on my car. Its as stock as a rock for all intensive purposes, and well kept.
Those are the police I refer to as **** who dont do their jobs.
Cops just rand and said the car has been found with no plates and shit and they have poured power steering fuid or something all through the inside so will have to see how bad it is when I get it back tomorrow!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
