I have a say.. 'pulsing vibration' in the pedal until the clutch is disengaged
(moving the pedal in and out you can feel it both ways)
and a ticker/rattle from the box that tends to come and go at times, more noticeable when its cold and goes away more when warm.
Does someone know what these mean?
thankkss.
https://www.sau.com.au/forums/topic/371250-clutch-problem/
thankkss.
Is the pulsing vibration there when the engine is stopped as well as running or just one or the other?
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-5917990
It is likely that you either have a broken spring in the clutch plate or diaphram. If the fingers of the clutch cover are uneven, then as the clutch rotates it will be moving the release bearing over the high/low spot on the fingers and hydraulic pulse the slave cylinder up to the master and through the pedal as the recovery port is blocked when the pedal is depressed.
I would check the usual stuff like pivots and slave cylinder first but I'm pretty sure your gearbox is going to need to come out :(
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-5918581
  • 7 months later...
rather than start a new topic i figure id post here. i have the same problem in my r34, its not bad but just enough to annoy me. i replaced the standard clutch with an npc recently so hoping its not a broken spring, but the input shaft did have 0.8mm of lateral movement due to a worn input shaft bearing i believe. is it possible that the movement of the input shaft is causing my vibration, or is it still likely to be something in the clutch broken??
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-6264628
did you machine the flywheel?
dont always jump to something major broke.
try thinking of more simple explanations.
if the flywheel was machined, then start looking at the dampening springs in the clutch plate, and go from there.
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-6265262
yea i did machine the flywheel, ive got an npc heavy duty organic, so im assuming it has stiffer springs?? and that you would feel more vibration over softer springs right? (i know its trivial, but it makes sense in my head :P) i was really just wondering if the play in the input shaft would be causing my vibration. same idea as the broken spring that as it rotates it causes pluses through the slave which you'd feel in the pedal
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-6265481
ive got a spigot bush, but i replaced that as well. also new thrust bearing that came with the clutch. ive also got vibration in the gear lever that i assumed was from the input shaft bearing, hence why i thought it might also be causing the vibration in the clutch.
https://www.sau.com.au/forums/topic/371250-clutch-problem/#findComment-6265833
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
