Hi everyone selling of my parts
everything is in very good condition to brand new
selling my items as i will be selling my car later on.
TE37 SL 18*9.5+22 wheels full set
They are brand new and still in boxes
$3200
Greddy oil cooler relocation kit
for R33 GTR
$700
full set of Hankook tires 265/35/18
70% tread
$550
R33 gtst banana bar unpainted
$300
R33 gtst half cage done from brown davis
comes with bolts and brackets with camera mount
have papers to.
$800
Power Fc with hand controller for R33 gtst S2
$1400
pictures still to come can mms photos to.
all items are in melbourne can post most at buyers
expense.
you can contact me by PM or call 0432886568
Thanks Dean
https://www.sau.com.au/forums/topic/371340-r33-and-skyline-goodness/
I belive that it will work in a s1 I just put up s2 cause that's what my car is. I have had it for 2 years now and has been I'm my car for that long to. There is no damage on it at all.I am firm on price to. Thanks Dean
