How do you explain to RTA about the speedo readings being different out of curiosity??
If you want to find more info out, search the forums, dont chat in here. Im sure the RTA has no problem with your speedo showing 300 instead of 180... As you will notice most australian cars show over 180 on their speedo.
Nismo R33 GTR 320km/h white faced cluster with 39,852kms. It's still in the original box, $700ono.
I'm in Sydney, but will ship anywhere if purchaser pays for postage.
Please sms(preferable) or email me your number as I will be in Sydney later this week and I can pick up the dash. Ph. 0419277774 email [email protected]
Thanks,
John
  • 3 weeks later...
Dave: FYI I was enquiring about the problems possibly to be encountered at the RTA NSW with ODOMETER readings being different, also I was asking the OWNER as he/she has the unit and may know this information possibly off hand. As I was a genuinly interested purchaser of this particular unit at the time I feel I was entitled to ask such a question, not only for myself, but other probable buyers.
To be publicly told "dont chat in here" annoyed me because of the above mentioned. As a moderater I think you need to review your tact!
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
