  • Replies 40
The RE001's were 'better' than the 595SS in my opinion. BUT, keep in mind the rather large price difference. For what the 595SS's are, I would get them again. I don't think the 595SS is really that far behind the RE001's, maybe you should consider the 595EVO (which is one between SS and RSR) or even the RSR's. I think if you get the SS expecting them to be the same or better than the RE001 you will be dissapointed, but if you get the SS looking at the price gap between the SS and the RE001, you will be pleased. If that makes sense. haha.
I wouldn't buy locally if you want a good tyres at a reasonable price .buy ad08s or dunlop speed stars for street tyres with grip. You can't expect a cheap tyre with performance to last ages. I run ku36 up front and federal RSR down back. Perfect combo for street Tyres that are good on track. If I wanted great on track, then obviously another set of wheels and semis would be ideal
I think unless you are competing (phillcom rally, etc) or have a large disposable income, dont bother with an amazing rim/tyre combo. Go a RE001, 595SS or KU36 and work on other small adjustments that will see your times drop.
but whats the point of spending $2000 on a set of real semis to cut a few seconds on the 3 practise days you attend a year?
no point in spending the coin for a few trackdays. there are plenty thougout the year, Ill be at the August 19th day
sorry J-rad, not everyone runs BCT's by choice
Maybe because my cars a daily driver, so cutting tenths of my drive to work isn't really that important to me.
But in the few weeks I drove around on Adrians CSTs with 595s I was impressed with them, never really tramlined or anything. Well worth it compared to KU36 etc
there is absolutely no way I would put top shelf tyres on a daily driven car. As it turns out, my 32 is daily driven, and the 595SS gives me a nice daily drive, but you can poke a bit of fun at them as well and they are fine. For $140 a corner, I simply cannot complain. Keep in mind that is $140 fitted and balanced, its all well and good to buy tyres from interstate for XXX price, but youve got shipping, then fitting and balancing. I'd rather give my money to a local business who is offering a good deal anyway.
Keeping in mind that your tyres are the only part of your car that touch the ground Damo :P
i'm probably going to either try some KU36's or 595 RSR's next time i need tyres.
for me, my car doesnt see much driving, but when it does i want it to grip well. last thing i want is something that will just spin if i put the foot down. for some reason spinning wheels doesnt get me hard like it does other people.
if i drove daily and needed the tyres to last, then i'd go for something harder compound and maybe not as much grip.
now i got a house and the missus can see the bank account, i've gotta spend wisely on the GTR
i'm probably leaning to the RSR's because for the price from option 1 garage, i can rotate them better since my car does get a bit of camber wear on the inside. and i think KU36's wont last and i'll have one side bald with heaps of tread on the outer side
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
