FYI I am assuming you want these to fit a sedan? It will be a challenge to try and get the 370z 19"s to fit the rears as they are a 9.5 +15. Ur car will need to be massively lowered, stretched tires and also a fair bit of camber dialled in. For a coupe it will be fine.
Hah! Good luck with 10 +15. I'm running 10+43 at the rears and they are already sticking out by about 7mm with a mild drop. Not saying it can't be done but as a daily driver it ain't worth the hassle.
This is what 8.5 +0 and 9.5 +10 looks like.
http://rimtuck.com/photos.php?photo=1283452472.jpg&id=870&h=3
What you willing to pay? i have the stock V35 18s off my coupe some gutter rash from previous car owner but it is fixable i have been told. im in NSW also so you would prob have to have them shipped, has Kumho rubber on them lots of tread left.
Edited by T4NK
Thanks.
I'm quite newbie with wheels. Had a feel 19x10+15 would be quite hard to fit in under any car especially the front!
Ok so here is pics of my wheels. you can see the gutter rash on them, I was told 2 would just need to be machined and 2 need some filler and a machine, so i went a bit over with all the pics but i want ppl to know what they are buying, i have been told that its fixable by a tyre shop and there seams to be lots of tread left on the Kumhos you can see tyre size and brand in the pics also.
It wont let me edit the above post so ill add this also, im looking for something around 600-700 mark, i had a quote for the tyres for new ones and to get the same it was around 1.2k for all 4 i know the rims are damaged but they are easly repairable for around $300 so i think between 600-700 is a fair price, if i am wrong please let me know im just going off what i have seen sell in the forums before.
I think you're probabaly pretty close to the mark with your sale price :thumbsup: especially with good rubber, they have very minimal damage.. I bought a set to use on my Stagea that were more damaged than these for $350 without usable rubber.
The thing to remember with the Shadow Chrome finish, is the paint itself is over $200 per litre, and requires multiple coats. It also requires all four rims to be painted at the same time. It starts with a black base coat and is built up with the Shadow Chrome finish; getting progressively lighter with each coat. I had quotes of $250 per wheel for this finish.
You'll pay around $600 for refurbishment and a good 2pack paint job; this will stand up to anything you can throw at them.
Another way to go is powdercoat; from around $50 per wheel and you can get pearl & metallic colours (they do cost more).
Link to get an idea of what you can acheive; http://www.cravedcoatings.com/
Not trying to tread on your toes; just sharing my experience. I really wanted the Shadow Chrome, but ended up with Toyota "Tungsten" on mine; looks really nice.
Cheers, Dale.
Edited by Daleo
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
