Hey guys,
Ive decided to part out my car and sell it soo ive got the following parts for sale. Just PM me if your interested :)
Genuine Nissan Aero Front Bar with Fog Lights
This is a genuine nissan Aero front bar which was bought brand new and is less than 2000KM old.
It was repainted pewter silver and is in mint condition with little to no scratches on the bar.
These front bars are $3000 from Nissan.
Price: $1800 ono
I will swap for a stock ADM bar plus cash
post-86687-0-41161800-1311659644.txt
Custom made carbon fiber front strut brace for s15/s14
This front strut bar was custom made and is harder than any other metal strut brace you will ever find.
Price: $350
Front and Rear Whiteline Sway Bars
Im selling both front and rear whiteline sway bars with the endlinks.
Both these bars are less than 2 months old.
I will not seperate the bar and the endlinks, must be bought together.
Google for pics.
Price: $250 each
Smoked Yashio Tail lights
These yashio tail lights are the smoked tail lights, so this means they were smoked in the factory,
not some dodgy backyard job. These style of tail lights have been discontinued from the Yashio Factory, so they
are becoming harder and harder to find.
Price: $350
BC BR Racing Coilovers
These coilovers are 3 months old and after owning a pair, i must say i am very impressed with the quality of them
The BR series coilovers come with:
Pillowball upper mount
Camber adjustable top mounts
Aluminium top plates
30 way adjustable damping
Adjustable spring platform
Height adjustment via bottom mount to retain full damper travel
Bearing mounted upper front spring platform
Dust boot to protect damper seals
There are no problems with these coilovers and i am just selling them because I am taking my car back to stock.
Price: $700 or $600 and swap for standard suspension.
S15 Standard 6 Stacker CD player
This is the stock s15 standard 6 stacker CD player which I took out of my car and replaced it with an aftermarket headunit.
Price: $300 ono
Edited by s15kid
https://www.sau.com.au/forums/topic/372123-s15s14-bits-and-pieces/
  • 1 month later...
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
