Hi Ppl
My name is Mick and this is my R32 GTST
I have owned plenty of cars althou this is my first import
03 XR6TURBO 455rwhp , 4 Vl calais turbo's one a calais aero turbo , supercharged 929 mazda
To cut a long story short i bought this car and went to register it and came back with the fact that the engine in the car had been stolen and not yet recoverd..,,,, see here : http://www.skylinesa..._1#entry5764020
Car was stock with just a cat back exhaust and 19'' rims
Any way i decided to purchase a new engine from silver gtst off the forums so i ended up with a low k (98,***) auto RB20DET travelled down to sydney and picked up the engine hoping for a decent running engine it was already out of the car.
OK so now i had the task of swapping the engines over and doing a major service on my new engine , timing belt ,water pump, crank seal , spark plugs , belts alot easier doing it out of the car (first time doing a major service btw)
ok so old engine out next to the new one
Can you tell which is my new motor? haha
Time to fit up my China spec turbo , now i bought this turbo from a factory in the midddle of china and the same guy makes crankshafts , cant be to bad can it? lol
as you can see big differece from stock althou i need to port the wastegate hole which i didint do while it was out :(
So while the bay was empty i installed a gktech solid steering bush and removed the aircon
The clutch didint look to healthy to while the gbox was off the engine i bought a Exedy hd clutch (nothing to serious , rb20 boxes are like glass imo) and had the flywheel machined
time to remove the auto spigot PRICK of a thing ok so all was bolted back together and started to think about installing my new engine
Bought a GTR fibreglass front bumper , car had a m spec bumper on it when i bought it
ok so after a weekend or 2 i had a running car
Time to get some rego and drive the thing
Had a little bit of fun at a ghetto skid pan nothign big as this was not long after i got it all running
<iframe width="425" height="349" src="http://www.youtube.c...bed/S3D7q2HKLYY" frameborder="0" allowfullscreen></iframe>
ok more to come soon
https://www.sau.com.au/forums/topic/372306-kebab_drifters-r32/
Looks good mate, haha i rebuilt one of these with my brother once, it started and expected to do the same thing, a engine swap and do major service on the new engine, then while searching we ended up buying a rb25 and building it to a 300kw motor hahaha. and it was alot longer then a couple of weeks
  • 11 months later...
So i replaced the stock dump pipe with a 3'' bellmouth
increased the spool time as the turbo is quite big and a little laggy , nothing a clutch kick doesnt fix LOL
So while the motor was getting installed i replaced the timining belt and water pump (big job for a first timer)
in went a new 52mm radiator , and would you know it big lauch and the fan hit the radiator smashed it to pieces and broke my new water pump $$$ later had it going again
Picked up a genuine N1 GTR bumper , these things are so much bigger and bulkier then the fibreglass copys , only problem is its missing an intake vernt but im chasing one up
gave it a coat of paint in the shed
Ok , so a bit of an update ran a set of EUROLINE 18x9 +20 front 18x9 +20 rear for a little while
ran some 19x8 30 somthing offset BBS MESH C1 copies plus polished the car up and can see the genuine gtr front bar
Got some aftermarket mirrors from GKTECK.COM
Bought some Rota grid r in gunmetal 18x9 +25 with a 8 mm slip on front and 18x9.5 +25 rear and got some low
Tien HR Coil overs maxxed out
I then installed a nistune got some gtr injectros highflowed z32 afm and a tune
then drove the pants off it
realised the ebay turbo wasnt doing the rb20 any justice i bought
and a retune by JEZ
HKS 25/35 turbo
  • 3 months later...
Ok so i fitted up some parts dumped it and maxxed out the tein coilovers
Crusing down the road spot an unmarked hwy was about 1 mins from my house and got pulled up in my driveway and got defected for wheels to wide , sticking outside the guards too low exhaust and airbox
somthing diff
Decided to buy myself a present Mint S2 RB25
Perfect turbo to go with it HKS 30/37 Pro S .87 rear housing internal gate
old turbo on the 20 hks25/35 double the hp :)
awesome wgate design should flow well
nice dumpsetup and clutch im running
installed SARD 550 injectors
thought if im going to do it ill do it properly and bought my self a r33 gearbox and got a custom tailshaft made up
installed and wired it up myself got it running
took it to DVS JEZ to get the dumpipe modded and External Msd switch wired up then tuned , was asked what results id be happy with and my reply was 260rwkw or 350rwhp . now i knew this turbo had produced some good numbers from the previous owner 350ishrwkw forged RB25 E85
Fingers crossed
HI BOOST VS LOW BOOST
RB20 VS RB25
Huge difference it went well with the rb20 ! Cheers DVS TUNING (JEZ)
fitted a roof lip and led taillights
some sweet sideskirts
Hicas lock bar
Camber arms
removed paint off rims and gave a quick polish
Goes hard lights up 3rd no worries ITS A BEAST
looks like a gtr here
At the moment there is a huge defect blitz in newcastle ''Operation hammer ''
so im trying to run under the radar sleeper spec what do you think?
gtr lip off
sideskirts off
pods off
all stickers off
stockies with big tyres
airbox
Time for a drive ...... ;)
Edited by KEBAB_DRIFTER
  • 1 month later...
  • 6 months later...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
