hey guys, i have a r33 gtst skyline and have just reciently intstalled the apexi PowerFC and hand controller. The rest of the car is pretty stock, except for 3in exaust. The FC is still in its base tune. What i have noticed though is if i give it a bit, it's not too hard to get the FC to flash up 100% duty cycle for the injectors (or close to it).
whats the most logical cause for this, injectors or fuel pump on the way out?
leigh.
https://www.sau.com.au/forums/topic/37231-100-injector-duty/
Most logical cause is the the base map is set up for greater fuel delivery to take into account more mods than you have (ie is tuned rich).
Get it on a dyno and tune according to the air/fuel ratio. Will probably find that you'll gain power as well as reduce fuel consumption.
https://www.sau.com.au/forums/topic/37231-100-injector-duty/#findComment-745695
Guest INASNT
just get GT-R injectors ,pump,FMIC,POD and youll fly .. 13 seconds garunteed.
that wouldnt cost you much.. how much boost are you running ? you must be on atleast 11psi to max out the injectors and fpump
bahahaha!!!
U have obiliously have not done any of these in your car have ya?
B33st
If u got stock everything else then ur injectors shouldnt be maxing out.
Get the injectors ultrasonically cleaned and checked coz they must be a blockage somewhere, or your fuel pump is cactus. Also if u continue to drive your engine will be pining up high with the base maps
https://www.sau.com.au/forums/topic/37231-100-injector-duty/#findComment-750702
I have already purchased new 044 fuel pump, sx reg, surgetank. Also no the way are a Greddy Plenum, Q45 afm + throttle body.
Had just put the FC in and given it a bit or a run to see how it would go. Ran like normal, except for the fact that the hand controler was easy to get to show 100% duty, never showed more than 17 on the knock meter though.
as soon as i get the plenum etc, will installing all the bits and taking it to ARE (QLD) for custom cooler / piping job.
then its time for a tune, and i guess i will find out if new injectors are needed too.
leigh.
https://www.sau.com.au/forums/topic/37231-100-injector-duty/#findComment-751564
yeah am working towards the turbo...
I wanted to do my build-up in 2 stages.
1. support systems
2. big turbo and big boost.
i pretty much have all the support items now(see last post). so ill get them installed + tuned and it'll then just be a matter of waiting till i have the funds for the turbo.
leigh.
https://www.sau.com.au/forums/topic/37231-100-injector-duty/#findComment-753226
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
