Ok this one has me buggered,
Just got car tunned was driving into work, almost at work then car lost all power, I suspected fuel pump because o was told the walbro gss 342 ( think that's the code) are crap, so i got into work ordered a new one, put it in and nothing pump isn't even priming, checked the PFC, found it's giving a signal, checked both relys and they are fine, checked the fuse ok. So we bridged the rely so the pump was constantly running, tryed to start and nothing just Cranking.
Car is a 1997 r33 gts-t series 2.
Any help is very much appreciated. Thanks
https://www.sau.com.au/forums/topic/372337-car-wont-start/
Is there power and earth at the pump?
Try to power up the old one off a battery directly and see if i works.
If it does then Double check the Power and earth at the pump in the boot.
If this all works out then check how u mounted it. If u used a hose clamp to hold to the mount then try backing the clamp off a little
https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5938877
Funny I was just about to post up a thread for help haha .
Ok heres a story about my GTR hahah..
I was on my way to the SAU drag day... turning right on to loganlea road first gear takes off fine... turn the corner give it a little bit more gas and
Engine stops dead in its tracks and won't start...
The check engine light keeps flickering on and off on and off if I try to start it...
Checked the usual things Intercooler piping, plugs, coils, fuel pump still seems to prime and run so thats good and gives fuel pressure to the gauge...
It turns over fine but just does not want to fire....
Now the idea I had was try change the ignitior pack so I lined up my mates at field garage who have a track 33 gtr... well that didnt work..
I went and spoke to a guy that I know who works alot on cars and said he thinks it might be the Crank angle sensor has gone??? So I guess thats tomorrow jobby.. but I am just curious what you SAU gurus would have to tell me to check?
https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5941296
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
