r33stocka Posted July 28, 2011 Share Posted July 28, 2011 Ok this one has me buggered, Just got car tunned was driving into work, almost at work then car lost all power, I suspected fuel pump because o was told the walbro gss 342 ( think that's the code) are crap, so i got into work ordered a new one, put it in and nothing pump isn't even priming, checked the PFC, found it's giving a signal, checked both relys and they are fine, checked the fuse ok. So we bridged the rely so the pump was constantly running, tryed to start and nothing just Cranking. Car is a 1997 r33 gts-t series 2. Any help is very much appreciated. Thanks Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/ Share on other sites More sharing options...
r33stocka Posted July 28, 2011 Author Share Posted July 28, 2011 Forgot to mention mods: Splitfire coils, PFC, sard 550, z32 afm, greddy profec b 2, greddy turbo timer, walbro pump, that's about it to do with eletrics Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5937917 Share on other sites More sharing options...
DVS JEZ Posted July 29, 2011 Share Posted July 29, 2011 Is there power and earth at the pump? Try to power up the old one off a battery directly and see if i works. If it does then Double check the Power and earth at the pump in the boot. If this all works out then check how u mounted it. If u used a hose clamp to hold to the mount then try backing the clamp off a little Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5938877 Share on other sites More sharing options...
DVS JEZ Posted July 29, 2011 Share Posted July 29, 2011 Is there spark and fuel Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5938878 Share on other sites More sharing options...
FTO Posted July 29, 2011 Share Posted July 29, 2011 If you can run the pump by bridging the relay, there's no signal from the ECU to the pump relay. Check the CAS..seems a bit co-incidental if you just had it tuned. Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5939374 Share on other sites More sharing options...
r33stocka Posted July 29, 2011 Author Share Posted July 29, 2011 there is spark. when we bridge the fuel pump it still wont fire. starting to lean towards cam angle sensor. Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5940079 Share on other sites More sharing options...
r33stocka Posted July 29, 2011 Author Share Posted July 29, 2011 also... whats the best way to check the cas?? btw the cas is getting power. checked that tonight aswell Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5940085 Share on other sites More sharing options...
DVS JEZ Posted July 30, 2011 Share Posted July 30, 2011 Check if its got spark and injector pulse. If so cas should be fine. Then check timing with a timing light to make sure the cas is adjusted correctly and the shaft isnt broken Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5941225 Share on other sites More sharing options...
EAT26 Posted July 30, 2011 Share Posted July 30, 2011 Funny I was just about to post up a thread for help haha . Ok heres a story about my GTR hahah.. I was on my way to the SAU drag day... turning right on to loganlea road first gear takes off fine... turn the corner give it a little bit more gas and Engine stops dead in its tracks and won't start... The check engine light keeps flickering on and off on and off if I try to start it... Checked the usual things Intercooler piping, plugs, coils, fuel pump still seems to prime and run so thats good and gives fuel pressure to the gauge... It turns over fine but just does not want to fire.... Now the idea I had was try change the ignitior pack so I lined up my mates at field garage who have a track 33 gtr... well that didnt work.. I went and spoke to a guy that I know who works alot on cars and said he thinks it might be the Crank angle sensor has gone??? So I guess thats tomorrow jobby.. but I am just curious what you SAU gurus would have to tell me to check? Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5941296 Share on other sites More sharing options...
r33stocka Posted July 31, 2011 Author Share Posted July 31, 2011 K got mine sorted was the cas. But also my braided line for My turbo feed ate through the loom and arced out blew a hole in the turbo feed and fryed my fuse Box. Lucky I was 100m from work.... Link to comment https://www.sau.com.au/forums/topic/372337-car-wont-start/#findComment-5941678 Share on other sites More sharing options...
