23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 211
Is'nt that prospect??
Either way we happy for a 8:30 depart from the carwash then.... the one in Parafield that is
OLDS: could you please edit your post with the new time
"Legs forum" start time has been amended to 8.30am... !
"the OLD fella"
The way its going my stag will be lucky to see daylight if i cant fix this stupid problem in the next couple days :ermm:
you will be right brother the stag will have 5 on the floor by then :devil:
Sorry bout the blank post above.. I Phone loves multiQuote lol ! :domokun:
So anyone else kicking off from anywhere near?? Keen to drive up with a few stags! :whistling: Or if anyone on the way to the meet point wants to join up b4 I'm down!
Jase still keen as for the meet b4.. Is Dream15 still in? What time you boyz heading off??
:cheers:
yeah still keen mate will give ya a buzz to organise catch up :thumbsup: and i reckon dream 15 will be right too......... i think ive run out of time to get my 33 brake conversion done and sway bars on but maybe sat.... and yeah im nearly ready zekie :ph34r: probs 2 weeks :banana:. alloy rad comes mon too
^^Is there anywhere between the corner of south/sturt rds and the southern express way you can pull over?
You could join us on the way past if ya want :thumbsup:
What why are you guys heading..?? Where u all meeting up? South n strut road ain't far..
Jase Wattt 2 weeks until X-mass :banana: it's taking for eva this year haha
Almost bought 32GTR fronts then the 33gts front but sumthing keeps stopping me! Haha :D
Went for the paint 4now as you would know but times killing me 2! Happy if I get the hearse clean insidec n out in time ! :blink:
Last time we went down the freeway, were all meeting at parafield airport.
Just thought we'd be going that way and knew you'd be close.....
Hey guys/gals, sorry for the late request, any chance of joining in on this cruise? i can meet up with the crew at parafield bunnings. Will be another C34.
cheers
Dave
Hell yeah!
For once I wont be the only yellow one there!
Hell yeah!
Sounds like this should be a good turnout, Don't forget to fill up those fuel tanks, there is only a crappy woolworths servo at the meet point and i'm not even sure it will be open on a sunday morning!
Really??
We going to start this again???
If I didnt love the bayside blue so much I'd, I'd, I'd...... Oh and the Dayz kit........ and the carbon bits and...:wub:
DAMN YOU AND YOUR SEXY CAR!!!:rant:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
