Tidy car, got to go, It just sits here doing nothing.
1996 series 2
7 months rego
Dual airbags
HID head lights
2 tone Interior re-trim with nissan logos
JUN bodykit
Bosch 040 in tank
3" turbo back exhaust
Apexi pod filter
Front mount IC with custom piping
Gates racing timing belt
Whiteline adjustable sway bars front and rear
Adjustable rear camber
Hicas lock out bar
A1rm brake pads F&R
Alpine headunit +six stacker
Pioneer 6x9's
Cadence 6.5in Splits
Cadence amp
Kicker sub
Tinted windows
Short shifter
$ 8,500
https://www.sau.com.au/forums/topic/372702-1996-r33-gts-t-silver-coupe-manual/
It's a sad reality aye?
I sold my 1998 R33 Series II 40th Anniversary Edition for $9.5k last year
Guys in Australia are becoming gay, most of them couldn't even drive a stick
Tell me about it , there's been bugger all interest in it even though every other car in this price range is either
4 door, Auto, Non turbo, Trashed, Series 1, Damn Fugly, or a combination of all of them !!
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
