im currently looking for wheels for my s2 r33, i would like to put 18x9.5 on the front and 18x10.5 on the rear, i know ill have to roll the guards
but can it be done with out putting spacers in, and what would be the best offset for the front and rear, stock brakes but will eventually upgrade.
not too sure on this subject. oh and its being built for a circuit car not drifting.
thanks for the help
https://www.sau.com.au/forums/topic/372819-r33-offset/
I've currently got 19x8.5 on front and rear with 245 tyres with standard suspension, they do scrub when taking a corner with bumps in it as expected but normal driving their all good, would not recommend anything wider for circuit with stock guards though.
https://www.sau.com.au/forums/topic/372819-r33-offset/#findComment-5946908
i had 18*10 + 18 all around with 265's all around. Rolled guards and a bit of camber work on a 33gtst. Only slight scrubing on hard cornering ( at wakefield) due to the springs rates being too soft.
cheers mate ill give that a go.
https://www.sau.com.au/forums/topic/372819-r33-offset/#findComment-5948120
I run 18x10.5 +22 rears with 235/45 and 18x9.5 +22 with 20 mm spacer and 225/45
Tires are stretched, fenders rolled and pulled. Looks absolutely bad ass, handles like poop
18x8 and 18x9 was my previous set up and rolled the fenders. That fit was good
https://www.sau.com.au/forums/topic/372819-r33-offset/#findComment-5948926
https://www.sau.com.au/forums/topic/372819-r33-offset/#findComment-5948951
tnx mate..appreciate it.. maybe you can post some pix from the side if you got one.. cheers
https://www.sau.com.au/forums/topic/372819-r33-offset/#findComment-5951967
How low? got pics thats a big wheel for front on stock guards
pics pics pics
https://www.sau.com.au/forums/topic/372819-r33-offset/#findComment-5951989
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
