As much as I would love to attend SAU Nats I won't be coming as the bank is low as is my income and just simply can't afford to but if i win the lottery before then (doubt it) I will gladly attend. Well done to Ash and all the other SAU people who have come together and organised this, hope it all goes well.
Fliggy come with me, the commodore will nearly get there on just 1 tank, and we'll share a room.
  • Replies 301
Posted Images
Dion - sounds good, is the SV6 one of those SIDI models i think they get 900/tank
Tim yeah not sure on last date for booking
a lot of people are at WTA so they cant respond yet, i will ring the Park next week and get a rough booking down and find out when they would like a deposit
I may be along for this. Will be doing a track day at Phillip Island on monday 31st. Would be silly not to swing by for the weekend and enjoy Skyline heaven. ;)
Ye a few other people are looking pretty much that same thing!
There is also a Sandown day either a week after or before as well - hopefully after Superlap is done we will see some interesting cars confirm they are coming too :whistling:
As soon as you know could you let me know please? Super Dooper Keen
I'm pretty sure I'm going to be coming as well, will take anything with a matress to sleep on for accomodation.
How are you getting there? See what the other 3 guys say but we might be able to fit you in the car, it is a 'family' car lol. The place I'm eyeing off for accommodation sleeps 5, but I need to check where everyone else is staying first.
edit: are most people (as in outside of SA) staying in Shepparton or Benalla?
yeah well Im just thinking the show'n'shine is at Shepparton so maybe we should stay there? Will mean a bit of an earlier start for the track day, but we are likely to be unfit to drive after the show'n'shine...
Edit:
Event SummaryFri 28th - Arrival into Shepparton during the Day/Night <- Arrival into Shepparton.....
Sat 29th Day - Track day @ Winton Raceway
Sat 29th Evening - Finger food/group function & Track Day Trophies
Sun 30th - Show'n'Shine @ Shepparton Showgrounds. Trophies for S'n'S in the afternoon.
Mon 31st - Depart and head home from one awesome weekend!
I'll see if I can find out where the Saturday night stuff is, if its Shepparton I think that pretty much seals the deal for me, don't know about others.
other thing that you guys may want to consider (as I've been to both towns)
Benalla is a bit of a shit hole with barely 9,000 people living there.........therefore motels and cabin parks are average at best
Shepparton has around 50,000 population..........much nicer town and lots of decent accommodation to chose from
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
