  • Replies 301
Posted Images
BIG4 Shepparton Parklands
OK, I just rang the above caravan/cabin park and the owner said that normally he would be able to negotiate the "Min 4 night stay" deal, however, the last weekend in Oct is Melbourne Cup weekend and in this instance, it's not negotiable.
Other thing to consider is all the good parks will book out quickly so back to square 1 unfortunately.
as if people stay in shepparton to go see the melbourne cup 188kms away
and melbourne cup is the firt tues in november
AAMI Derby Day is 29th october but again i doubt people would stay @ shepparton to go there
While I won't be attending, I can recommend to ya'll to spend an extra day (maybe two) and head east along to Bright or Myrtleford. The Great Alpine Road runs from Wangaratta up to Mt Hotham along the ovens river, and connects to Hotham, Falls Creek, Mt Buffalo and Mt Beauty, all excellent roads with some of the greatest scenery this country has to offer.
You won't regret it.
-D
Country Comfort looks good guys........which actual nights are we staying though....and is it 2 or 3 nights?
EDIT: Just saw Dion's post
Event SummaryFri 28th - Arrival into Shepparton during the Day/Night <- Arrival into Shepparton.....
Sat 29th Day - Track day @ Winton Raceway
Sat 29th Evening - Finger food/group function & Track Day Trophies
Sun 30th - Show'n'Shine @ Shepparton Showgrounds. Trophies for S'n'S in the afternoon.
Mon 31st - Depart and head home from one awesome weekend!
So looks like 3 nights.....arriving 28th and departing 31st
would be different with cabins Steve cause you'd get a bunch of them that fit up to 6 people.....most rooms (other than the 1 family Room) will only accommodate 2 or 3.
As long as peeps know where the majority are staying, they are then responsible for the booking and money side of things :/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
