i run one with my rb25det its a lt12s however i only went the microtech because i got it given to me from a close mate who smashed his car otherwise i would have gone nistune or something but i dont have a problem with it
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5950162
Im also wondering is there something about them that will hold us back?
My new car has a microtech in it already and Im somewhat CBF to replace it..
If there was a major advantage I would do it.. Anyone care to sway me?
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951039
i agree ive got one already and cbf removing it and fitting AFM's etc
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951112
I just spoke to DVS JEZ quickly by sms, the basic outcome was to leave it and be happy.
Stuff like the link etc has more features but not really necessary stuff to get a good tune out of it.
In my case its an SR with VCT, I will put a window switch into it shortly and it will do everything I need it to..
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951125
my ltx12s is great,, for what i need it to do anyways?... and ppl make claims of bad cold starts, but mine starts up and idles fine when cold..
yeah my cold starts are fine aswell when cold will idle at around 1200 until warm enough then will idle at 950 i have no problem with cold starts etc
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951179
That's probably because the STD ecu is still there controlling the idle. They aren't the greatest of ecu's pretty sure they still batch fire even thought the should be able to run sequential inj/ign with ltx12.
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951213
Same with my 200, runs fine.. No stock ecu in place.
Just lazy on power, but I cant really blame the microtech haha.
Its actually as economic as factory too.. Eh we have our answers, nothing wrong with em for a basic setup.
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951418
i dont have standard ecu at all its just microtech liek i said its a rb25det in a vl commo so im runnign full aftermarket wiring loom no afm full map sensor and my cold starts etc are perfectly fine
Well sounds like they've pulled their finger out and worked out how to drive the extremely complicated IAC valve.
Can any of you comment on the sequential injection?
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951540
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
