microtech are not as bad as everyone says. its just harder to get working on a rb. very easy to tune but very hard to wire into a rb. alot of people use the plug and play adaptor for rb25s hard wire it in properly and its fine a bit of a hastle to wire in but once done its worth it.
like i said before if the microtech was not given to me i would have gone a nistune or PFC
The model number implies its drivers, normally halved.
An LT12 can do 12 cylinders batch fire or 6 sequential.
Correct me if I'm wrong anyone..
I know its meant to be sequential but the last LTX12 I scoped definately wasn't sequential - that was using a 36-1 inductive trigger and factory inductive cam trigger on a 2/1JZ. Apparently microtech's cant use too higher tooth counts and which means on an RB they are most likely only using the 6-5-4-3-2-1 signal not both the 6-5-4-3-2-1 and 360 tooth signal like the factory/PFC do.
Hence why there is very few ECU's that I trust to use the OEM RB CAS for stable igntion control.
i've had microtech's on a few cars now, I think they serve their purpose, cheap to tune & simple, very broad in load points for tuning, best suited for drag cars and rotors. but if u don't mind turning the key a few times on cold days & warming it up for 5 mins then microtech will be just fine
if you don't ever plan to pass a emissions test, and you don't care about the microtech's timing drifts and you can be bothered with aftermarket aux's then go for it.
its just not the right way of doing things.
How well do they work as a piggy back?
I've an auto & I'm looking at a possible high flow turbo in the near future (nothing major, only aiming for about 220 - 230rwkw) & I'm a bit stuck on ECU choice.
Since no stand along aftermarket ECU works properly with a R33 auto (as far as I know from reading old threads), & some old suggestions was running a combo of SAFC + STIC, however the latter is nimpossiblebile to find. The other one was to run a Emanage Ultimate, but I found most tuners around my area dislike them for some reason, so no point getting it if I can't get a decent tune out of it.
I talked to my tuner about the issue & he reckons a micro tech wired in piggy back would do fine with a stock high flow.
Any opinions on this?
Edited by Mayuri Krab
Can you explain in more detail?
I thought the harsh changes where due to replacing stock ECU which backs off timing before auto changes gear with a stand-alone aftermarket one, which doesn't do that.
But since you retain the stock ECU wouldn't that mean this 'back off timing function' is kept as well?
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
