Hi Folks,
I had a loud rattle (sounded like two solid pieces of steel just touching while vibrating) from my steering column, so I removed the plastic cover to have a closer look, drove around a bit, it seems to have gone away and only happens now and then since. However, my horn now goes off at low speeds- like when I turn into a parking space. It does a series of short beeps, not quite full volume. I checked to see if there was a loose wire but couldn't see any. Anyone had this trouble, or know where I should be looking?
Cheers,
https://www.sau.com.au/forums/topic/373089-horn-keeps-beeping-help/
LOL how embarrasing, but yeah its a short somewhere, just look for worn insulation, probably going to have to back trace the wires from the horn button backwards.
i had a similar thing where my High beams used to randomly come on, this was on a barina tho, seemed to happen when i'm following a cop car pinch.gif
Thanks guys, yeah it's pretty embarrasing, went off at an intersection while I was waiting for people to cross, girlfriend finds it quite funny though. I have disconnected the horn now- it was a pretty loose male/female connection- but there was more than one wire connected with the same piece, so now my air bag light is staying on, plus I can't honk at the many annoying drivers! I'll check for obvious wear, then try and replace the wiring I guess. Hopefully I don't start honking any cop cars :)
Thanks for the replies.
  • 6 months later...
Found the source of this problem and the loud vibration- There is a small but heavy piece of metal that is part of the steering wheel and is there to reduce vibration, it had broken off and was bumping into things. I just had it removed and didn't notice much difference in the vibration, though I have VERY stiff suspension to start with. I was told the whole wheel needs to be replaced if I wanted to have one as it is built in. You need to remove a few things to get to it. If anyone is interested I can post a pic.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
