hey guys posting on behalf of a mate so dont ask me for further info cos i dont kno, call the number i provide please
r33 gtr v spec box (80,000)kms $950
n1 turbo and 2 stainless dump pipes with exhaust manifold off 33 v spec $650
rb26 bottom end no sump, cp pistons, argo rods, nos rated rings, acl race series bearings, jun collar, brand new n1 oil pump with after market billet gears. motor has been balanced but changed to a 3.0 litre bottom end $4500
also has a 33 gtr he is wrecking out and lots of various parts avail so just call for details. i know he has perfect rear quarters, doors, centre trio gauge pod and various other good condition interior and exterior pieces avail
contact roy on 0424775829
i will check back daily to answer any questions i can but as i said please just contact the seller
Edited by NUT515
https://www.sau.com.au/forums/topic/373141-garage-sale/
all items are located in toowoomba qld. postage can be arranged at buyers expense.
also avail are a
set of 18 inch 3 piece roh modena wheels with rubber for $2000
set of 18 inch xp racing wheels with rubber $1000
dont know offsets and widths will try and get pics for them
https://www.sau.com.au/forums/topic/373141-garage-sale/#findComment-5955851
u chasing the front or rear guards mate?? it is midnight purple in colour.
sorry mate no exhaust cam as the motor is already sold.
i will find out bout the plastic inner guards, the car did cop a hit in the front so unsure of the condition of the liners
https://www.sau.com.au/forums/topic/373141-garage-sale/#findComment-5973732
thanx so much.. if there still in shape and not cut or anyhing , should be good.. thanx :)
https://www.sau.com.au/forums/topic/373141-garage-sale/#findComment-5975844
  • 10 months later...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
