what sort of rims do you like? 3,5 or multispoke? one piece forged or 2/3 piece dished? I'm contemplating getting a different set of wheels, so if the wheels on my car are to your liking, just throw me an offer. size is19 x 9 & 10 +25 f/r Work sc2
LOL looks like my car.
  • Replies 43
if i were you i would check out ozzietypes in liverpool for the price of some of these used rims you can get a great set of new rims and new types
they stock euro, ameri and ozzie rims....and i priced my wheels and types in the states to compare them to the price and the price in Oz was cheaper.........and my typres in he states are expensive.......
i guess you have a bit of homework to do
Wizlb, and what are the brand/model rims on your car? Very nice...
Yo best rims for a V35 are the R35 GTR rims, check this shit out
http://www.carsales....words=&__N=1216 1246 1247 1252 1282 4294963593 4294963846 4294931980 397&silo=1011&__No=15&seot=1&PriceFrom=397&__Nne=15&trecs=24&__sid=130DCB311D90
And i also found where to buy said rims
http://www.wheelsrim...-inventory.html
you will need to use a forwarding service to get them tho, the company does not post out of the USA but you post to the forwarding comapny in the US then they post it to you.
Forwarding service
https://bongous.com/
Edited by T4NK
I run a 10.5" at the rear.
Its OK as long as you dont replace your suspension with after market coilovers and run a maximum factory camber... thats what I did last week and the rims now have a 2mm gap from the shocks. The rear wheel touches the shocks (metal to metal) every hard turn or if I pull into a drive-way. Breaks my heart. I had to add 3mm spacers at the rear to stop them from destrying each other.
This "might" be the same if your wheels are too wide at the front. I dont have this problem because I am running 8.5" at the fronts.
Yeah, they definitely look great. :)
  • 3 weeks later...
hey guys n girls im still looking for rims and it seems no shops around are all that interested in selling them to me, so anyone got some that are forsale to suit my v35 with brembos? 19 or 20" thanks!
  • 3 weeks later...
i got some rims finally, ended up with 19x9 +20 at front and 19x10+10 at rear, fits sweet! verry aggressive at the rear tho looks sweet! ended up with rota grids that just came out in 19's saved me some cash aswell will possibly look at somthing bigger (20") later on but my tires where shot and these where easy!
Hi Guys n Gals,
I've recently fitted 20x10.5's front and back (ADV 5.1's), no spacers and no machining, under Bilstein fully adjustable coil-overs. Pretty aggressive at the front, lots of tyre stretch and I still need to get some upper camber control arms and likely roll out the guards. The rear sits perfectly with no rubbing just using a mild setting on the factory lower camber arms and lipping the rear guards (Chris at Centreline Suspension is truly a master at fitment, just need to arrange him to fit the fronts under).
Pics as soon as someone gets a camera that's not my phone, it struggles focusing on all black.
Cheers
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
