Formatted my 1TB external as FAT32 through DOS, but after hours of it formatting, I woke up to the message 'the volume is too big for FAT32'
Anyone done it? What did you use?
I'm looking for a full version of swissknife as apparently that's what I need...
https://www.sau.com.au/forums/topic/373853-formatting-external-hdd-for-ps3/
I dont really download high def stuff so most movies are 700mb for me, and the rest of my files are tv shows. Don't have the Internet/a network at my new place yet either but might do that when I do. I was using vuze I think it's called at my old place to stream.
Wish the sorting system was better on the PS3's. I've got all my top gear on there. Wish you could make folders to put stuff in but oh well
You can...All my stuff is in folders exactly as it was on my hard drive when it was NTFS
You just have to make these 3 folders
'MUSIC', 'PICTURE' & 'VIDEO'
They need to be in capital letters. From there, put all of your video files in the Video folder (they can be in their respective sub folders, which don't need to be in capital letters...music in music...you get the idea
So basically
VIDEO
-Curb Your Enthusiasm
----Season 1
-Seinfeld
----Season 1
They'll then be sorted in alphabetical order when you browse them on the PS3, and episodes will be in order if all of your files are named properly
This is transferring from an external HDD onto the PS3, making a folder on the ext drive 'VIDEO' then selecting it in your PS3 and copying it across?
Think thats what you meant lol..... Will have to do that anyway, will be lots better :)
Nah my external HDD is hooked up to the PS3, and all the data is on there, not on the PS3 itself.
Not sure if you can add folders to the PS3 HDD, but I'd assume it's possible if you pull it out and hook it up to a computer to do it...
You can't make sub folders on the ps3 and you also can't pull it out and hook it up to the PC and create folders either unfortunately. The easiest way is to just buy an external hdd or have a network setup to stream instead of having them copied on the ps3.
Edited by Dani Boi
Yeah that's all I've been doing. Have all my topgear on the PS3 itself but there in order so no biggy
As for the folders on ext HDD. I don't worry about it, just hit triangle and display all and it comes up with all the folders that are on there anyway
ps3 i found is also a bit picky with regards to what video formats it'll read and what it wont if your playing direct from external (e.g it wont play .mkv files). my guess is sony being a major player in the home entertainment publishing/producing sector they dont wana make it easy for people to play pirated gear.
ive tried a few media servers and i've found ps3mediaserver by far the best one, less of a cpu hog on the computer and generally easier to use from the ps3 end. transcoding is awesome, any format the ps3 wont read, ps3mediaserver will transcode it on the fly in to a format that works. with tversity and Vuze i had troubles with transcoding they were quite unreliable. ps3mediaserver by far the best solution for watching stuff on ps3 IMO.
ps3mediaserver
All sorted...After wasting 10+ hours formatting it only for it to fail at the end, I found and downloaded a program that formats it in 5 seconds :thumbsup:
So just out of curiosity what program did you end up using anyway? :P
I just bought a western digital mybook white light edition. Works faultlessly with the PS3. I didnt have to do any thing other than plug it in as per the instruction booklet. Being a total computer retard this was a very nice feature for me! Seems to encounter less streaming issues than streaming from the Laptop used to as well
Lol sorry, thought I mentioned it..
it was called fat32format (ironic..) Can't remember where I got it from, but its only a 23kb zip file...
  • 4 weeks later...
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
