Hey guys,
Here im selling my Nissan 180sx 1990 model. This has beenused as my daily for nearly a year, and I have used it on 2 track days forStadium Drift this year, and came 3rd in one of the rounds, so it is a verycompetitive and reliable car. The reason for selling is that it is time to moveon to something different and cheaper as I need to clear some debts.
This car has been serviced 4 or so times with the past yearwith minimal km's. I change it before and after my track days with Nulon oil.Great care has been taken on this car, i never limiter bash my cars as you cansee from the video below, i baby it when i thrash it! lol. Car has a few tinyscratches, rear bar and front bar has some minor cracks which are visible upclose but have be refibreglassed.
MORE PICTURES will be posted over time.
PRICE: $9800 onoor $9000 without thewheels, stockies will be provided. (need cash!)
Car:
1990 Nissan 180sx
Sunroof (does not leak)
5 speed manual SR20det
Rego included until November 2011
Engine:
Apexi PowerFC with controller
Z32 afm
HKS step 1 cams
Rocker arm stoppers
555cc Nismo injectors
TD06 20g (fresh core, no shaft play)
Trust external wastegate with 18psi spring and screamer!!(old school Trust ~50mm cant remember)
Custom steam pipe mid-mount manifold by Extreme TurboManifolds
HKS Super Dragger exhaust, 3" from turbo
Decat
Aftermarket fuel pump unknown brand (came with the car whenI bought it and you can hear it prime)
Larger oil sump (Trust copy)
Hybrid intercooler
Turbosmart plumbed back BOV
Pod filter
Larger s14 radiator
Hioctane radiator air diverter panel
Oil catch can
The car makes 220rwkw at 18psi tuned by Unigroup (tuned tobe super reliable for the track, knock reading never reaches >10, more roomfor power.)
Drivetrain:
Xtreme HD organic clutch (plenty of meat and does not slip!Its been surprisingly perfect)
SR20det gearbox in great condition, always use Redline MT-90in it
Shimmed diff (does not clunk, only chirps and is relativelylocked)
Suspension& Wheels:
HKS front coilovers with camber adjust
JIC rear coilovers
Adjustable rear camber arms (otomoto)
Adjustable rear traction arms (dproject)
Adjustable castor rods (dproject)
Steering rack spacers for more lock
Solid steering aluminium bush
HICAS removed with lockbar, HICAS lines are looped.
Rear QFM A1rm pads
Work VS-MX wheels 18x8 +26 fronts and 18x9 +26 rear
Toyo proxes front (65% tread)
'Clear' tyres on the rear (80% tread)
Alignment is suited for drifting, the rear is fairly neutraland the wheels are poking out a tad, front has -2deg camber. Spec sheet will beprovided.
Exterior:
Vertex style body kit
6000K HID kit
Custom rear tail lights
Front and rear guards rolled
Aerial removed and smoothed
Rear wiper removed
Interior:
Relocated battery in the boot
White NISMO Duracon gearknob
Autotechnica Wheel
Drift button
PowerFC Controller
MASSIVE Pivot boost gauge (bar)
Type-X passenger seat
Standard s13 drivers seat
Genuine standard 180sx mats
Pioneer Headunit with ipod connectivity
Contact:
Just PM me, ill get back to you pretty quickly
I may have missed a few things, but this car is a good dailytrack car that turns heads on the street. And who does not want GATE!YOU BUY NOW!
Bride seat and steering wheel/quick release (shown in belowvideo) will not be included in the sale.
Cheers
Jas
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
