Gah, you don't lose points, you get demerit points. Here's how it all works:
- Earn 12 points in the space of 3 years (as a P plater or full licence driver) and you will get an option notice.
- Earn 5 points in the space of 1 year as a P plater and you get an option notice.
- ALL points regularly take 3 years to expire, UNLESS you get an option notice...in which case, you will receive a clean record (0 points) at the end of the chosen option (1 year good behaviour, or 3 month suspension).
- Points that are earned as a P plater do not "expire" after 1 year, they stay on your licence record and still count towards the 3 year rule, they just no longer count towards the 1 year rule.
I agree with what you're saying but now P Platers have reds for 1 year and green p's for 3 years so how does it all tie in there?
No as in it now 4 years on P's meaning what happens after the first 3 years? Do P Platers still only get to use a maximum of 12 points for the first 3 years and it resets on the fourth year assuming no demerit points had been issued previously?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
