hey peoples, i can half remember someone talking about handing out pamphlets to skyline drivers telling them about this site. Im not sure if i was dreaming the whole thing or it really happened, but if someone knows anything of this then let me know, cuase i would like to help out handing around some if there are any, as im always getting around gold coast and see heaps of skylines, so i could probably hand a few out- try and get the gold coast numbers up- seems like there are more brissi then gold coast people........... :wavey:
https://www.sau.com.au/forums/topic/37414-sau-pamphlets/
sweet i will hand some out, hey how long did it take to get your sau stickers?
Did you buy them from Gary1, or streetweapons?
Gary could prolly get them to you overnight, streetweapons takes like 2 weeks, plus buying fron Gary gives funds to club :D even though I personally was too impatient, oh well
https://www.sau.com.au/forums/topic/37414-sau-pamphlets/#findComment-750899
Hey Ska .. im not going on thursday, any chance you can grab me one .. and ill get it off you when i see you next :D
PM Gary1 and GenesisR32 and work something out with them, I am not going for the cruise, just the meeting, but can meet up with glen and grab themoff him if you can get them to him :D
https://www.sau.com.au/forums/topic/37414-sau-pamphlets/#findComment-750930
