HAY GUYS
I HAV JST BECOME THE PROUD NEW OWNER OF A R33 GTR AND ALTHOUGHT I LIKE THE RIMS ON IT AT THE MOMENT I WOULD LIKE TO CHANGE THEM.
I WANTED TO GET A COUPLE OF SUGGESTIONS OF NICE RIMS N GOOD PLACES TO GET THEM FROM...THANX
https://www.sau.com.au/forums/topic/374249-r33-gtr-rims/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
