if your looking for the genuine ones from nissan JP they no longer stock them. as i tried not long after i got my V35.
you can get aftermarket ones from Japan, but mine were rather expensive.
Edited by liger
https://www.sau.com.au/forums/topic/374360-wtb-floor-mats/#findComment-5971655
Cheapest I have found is Import Monster using their Japan Auctions link. Its in English (for the most part) and by searching under V35 Nismo you will find Nismo floor mat sets $100+ cheaper than Japan Parts.
https://www.sau.com.au/forums/topic/374360-wtb-floor-mats/#findComment-5972371
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
