It's understandable vspec, just wanted current member reviews as I've known some workshops may change staff and quality of work can change abruptly. Plus I've made errors in judgement when choosing shops for random stuff before. This info has been handy.
Also http://www.wtfauto.com.au/ is the only contact details I have for them atm.
I'll let ya know the details of the guy doing my cams once it's done, although he specialises in hilux conversions and seems to know a fair amount about the 1uzfe. Can't vouch for his workmanship until I get my car back.
  • Replies 46
Thanks, I'll add there details today.
I understand the idea behind wanting to get info from members, however take alot of the advice with some level of caution, as there is alot of "a mate of a mate of mine had stuff done". Personally I think you'll find that over half of the tuners in WA won't touch the Emanage, which will reduce the pool straight away.
WTF Auto doesn't have there own dyno, so they do dyno tuning in batches on someone elses dyno, which depending on your level of urgency to get the work done may be a downside. But amongst the Toyota crowd they have a very good reputation.
http://soarercentral.com/sc-forum/messages/287/313271.html
Well it should run ok on the stock ECU for now so urgency won't be too much issue, however still confused as to why a lot of tuners don't want to tune the emanage, some specifics would be nice but that's not the sort of think I've been able to find after a lot of searching. I'm sure the tuners I've contacted will give me the options though.
Having someone familiar with the particular engine is a big head start in its own. Seems not a lot of people get work done to 1uz's in WA.
Already read up on that, thing is I need ignition control to raise the rev limiter and it needs to be a piggy back for now. I think I've just about read everything on the internet about 1uzfe's and ECU's
Yeah piggy back for auto control as well as keeping it's safeguards, plus paying for an SS4 or the likes on top of a full aftermarket computer is a bit of a stretch considering I only need some fuel trim and a bit of timing to suit cams, if I was going a decent boost I'd look for something better.
Ill pm ya now Corey
Peronsally I think giving Tristan a call, and asking his advice will be the best option :thumbsup:
I've updated the Consolidate Workshop thread with his details now :cheers:
Already emailed him yesterday evening. Don't want to be making phone calls until i've actually got my car back running, but now's a good time to start working on a plan of attack for tuning.
Thing should really start moving once it's tuned for those 4 lumps of billet.
Thanks mate, but none of those ECU's are what I need. I've done a bit more reading and it still looks like the only Piggy back that can raise a factory fuel cut is the EMU, not exactly spoilt for choice huh. And the 1uzfe isn't supported by greddy although a few people have used it with good results.
I guess I'm dreaming thinking there'd be more piggybacks with ignition control.
I still don't fully understand ecu's and how they work etc, but i do have an EMS stinger, and it is awesome. On their site http://fuel-injection.com.au/stinger-4-1-20-21-d.html it talks about ignition control. I had one piggybacked into my 20 combo and will more than likely be using it on my new engine. Ovaboost tuned it no problems at all.
Or you might be best talking to WTF like you have mentioned
Have you spoken to Andy at Hyperdrive? He is an official Greddy dealer, have seen the EMU in his shop. For what it's worth, when I was asking him about ECU's for my car, he told me to steer clear of the EMU... I understand you're possibly quite restricted in your choice of piggy-back for what you want to do, but perhaps a stand-alone ECU would be the best option if no-one wants to touch the EMU? I mean the EMU is not exactly 'cheap', you could find a stand-alone for a few hundred more and it will be better. And in the end, it all comes down to how well it is tuned, if tuners are staying away from it then there's probably a reason for it.
Yep already contacted Tristan, he can tune the EMU but still recommends a full standalone.
If Getting some cams put in wasn't costing me over 5 grand I'd be slightly happier to spend a bit more on management :-|
I know the units are are around the same price for standalone, but all the extra wiring and tuning from scratch will add up quickly. Plus these Auto's need the extra transmission controller unless ya fork out extra for an ECU that can do that as well.
Don't wanna manual it either :-p
5 grand for cams ? WTF (and I don't mean the company)
Seems the overall consensus is full stand-alone, might be best to hold-off the tune till you can afford it :thumbsup:
Guess the options are EMU, or drive around on stock ecu for a while and save for a bigger standalone job. Let's hope it idles with those cams in.
Another bonus to the EMU is you can go mafless, apparently the maf is quite a restriction.
That's the approx tally so far :-(, includes the purchase of the cams, springs. All the valve seals, plugs and some hoses and bits n pieces plus labour . Engine needed to come out to get the exhaust side valve springs and seals. Should be getting finished up by next week. *Fingers crossed*
Ouch, that still seems pretty expensive, fingers crossed it was worth the $$$ :thumbsup:
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
