NEW UPDATED LIST;
First RB20 (130,00K's)
Blown head gasket and exhaust valve, currently dismantled;
Bottom end is not that bad but the exhaust valve landed in the first piston bore and made some gouges in there :(
Head is seemingly fine except the exhaust valve will need replacing... offers on these two!!
Cams in perfect condition $ Offers
Second RB20 (76,000Ks)
Low Compression on 6th ran fine though just lean in the top end :(
Head is perfect (Just Tested) $250
Intake manifold $SOLD only the top half sold, still have sensors, 2x bottom manifolds etc.
Exhaust manifold (Just replaced with perfectly straight one) $100
Perfect Condition Cams $ Offers
Bottom end needs rebuild $ Offers
Also these Items;
1X RB20 turbo in decent condition $100
1X RB25 turbo in good condition minimal shaft play $SOLD
1X RB25 turbo suit rebuild, held boost fine just a bit smoky every few days $ Offers
2X RB20 ignitor packs $ SOLD
5X Rb20 Coils seem fine just installed one in my motor and it runs fine :) $25 Each
9X RB20 Injectors 6 are known to run fine 3 i've never driven with so may need to be tested $ Offers will sell lot or individually
1x RB20 Rocker Covers Painted metallic black $100
1x RB20 Rocker Covers silver oil hose connector is broken on one needs welding $30
1x RB20 Good condition Exedy Heavy Duty Clutch $ Offers
1x RB20 flywheel $SOLD
1X RB20 ECU - $SOLD
1x R32 standard rear bar pretty beaten up Silver colour $50
1x pair of Monza front R32 shocks Good condition sit at a nice low height, top adjusting nut of one is damaged $150
1X Perfect RB20/S1 RB25 AFM - $120
Coil Pack Looms - Sold
1x RB20 Intake pipe $40
4x Rb20 Cam Gears $20 each
1x Standard RB20 Coil Pack cover
1x R32 Reo plate for behind the backseat with bolts $50
Still have more wiring and sensors in good condition if your after any ;)
Cheers, Tobbie
Located in TAS
https://www.sau.com.au/forums/topic/374820-tons-of-rbr32-stuff-for-sale/
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
