i got a few parts i want out of the shed
r33 series 2 full set of trims great cond front and rear (2 door) $300
r33 series 2 center consol $50
fujitsbo muffler 3" came off r33 $100
r33 series 2 passenger door with window and mirror in good cond minus trim $250
r33 series 2 passenger side front guard good cond $200
everything is nearest offer want to get rid of it all
rather adelaide buyers jus for ease
pm or msg on 0409875003
https://www.sau.com.au/forums/topic/374869-r33-s2-parts/
  • 1 month later...
