Work VS-XX sprayed in black 18x9.5 + 17 and 18x8 + 8 = $2000 or $2500 with half worr R888 (235/40/18)
Nismo 2 way lsd R200 = $799
C's short shift kit to suit sr20det 5 speed = $150
S14 carbon fibre boot (brand new) = $399
Adjustable Castor arms (not sure on brand) will suit S14/S15/R33gtst/R34gtt = $100
Braided brake lines to suit S14/S15 (6 months old) = $150
Front R32GTR calipers = $249
Rear S14/S15 silvia slotted rotors and calipers (no pads) = $175
AIM My-Chron Lap Timer with beacon = $199
Ryan-0413804117
  • 3 weeks later...
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
