Hi All,
Have a used set of 25mm bolt on spacers (5x114.3) which I dont need - They have been sprayed matt black and are dirty as but I will clean them up before sale. Been used for the last 6 months with no issues.
$70 + postage.
Cheers,
Adrian.
https://www.sau.com.au/forums/topic/374973-25mm-bolt-on-spacers/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
