Ok just checked the cranking voltage on the fully charge battery, it only dropped to 9.9 at it's lowest. So a little bit low still but not as bad as 7.8.
And once started, both battery and turbo timer were reading around 14.4v.
  • Replies 78
Waaay to many long posts to read.
With the nistune and bigger injectors. Nistunes dont seem to recalculate the cranking tables when doing a injector resize. Sir rb's car was my first nistune and from his hot start issues and an rb20 i did last week i noticed they both required a fair bit of fuel to be removed on hit start.
Hanaldo. Drop the numbers from 35 or what ever it was down atleast 5-10 and try. Rememer to write to ecu after changine the settings and try.turn it off straight away. Rinse lather repeat
Thanks Jez, I'll give that a go. Is this on the Crank Enrich table? What about the crank enrich offset tables, do they need to be changed as well? The enrichment value on the Crank Enrich table is only at 8% from 50 degrees on-wards, I'll try lowering it slowly.
Edited by Hanaldo
Mmm didn't achieve much there. Tried changing the Crank Enrich table values (set at 8 normally) as high as 30 to as low 2. Didn't affect anything. Also tried changing the Crank Enrich Offset tables, but that didn't do anything either. I did notice the ECU was giving a code about the Throttle Motor Sensor? Likely related??
In any case, I think I've tried all I can. Need to take it back to my tuner. *sigh* more money :(
I'm another one having hot start issues with my r32gtr, it's not as bad as the guys in previous posts, it's taken maybe max 3 or 4 attempts before spluttering into life. I'm running a PFC with a reasonabley tame engine setup although some tomei drop in cams have been installed and not tuned with them, so could partially have to do with that (but cranks over first time everytime when cold).
Interested to see what the problem turns out to be. Goodluck guys.
Gotta read them long boring posts otherwise you wont know what people are on about. It was my car that I tried 35 ms. Hanaldo's ms figures are at 8 and 10. We have tried pulling fuel out and adding fuel.
Hanaldo don't even think about paying to get it looked at. We will get it worked out.
Try crimping the return fuel line when starting see if that helps at all.
Yep try it. That will rule out the fuel reg. I spoke to a bloke the other day and he reckoned that with bigger injectors, when you try to start the car they dont actually open for long enough to let fuel out. But both our cars start fine when cold and not when hot. Where are the common links here? I'm going to try crimping the fuel line tomorrow and see if that helps.
To me it still sounds like an injector issue or battery voltage issue to the injector.
I've had issues with some sard injectors not turning on around 8-9 volts with 4bar base pressure. We had to drop it down to 3bar to get it to start.
Its time to scope the injector pattern at crank and compare good vs bad. More specifically check the peak inductive ring voltage from good to bad and see if the the injector is properly saturating.
Either that or you could try patching another known good battery onto the injector harness.
I ran a chart for inj duty cycle with my datalogit when I was cranking. No matter what I did the injectors opened slowly from 0 rpm to idle. Even adding more cranking ms there was a spike after it started but still had the same initial slope. The injectors are definitely not working according to the tune at cranking rpm. Maybe that is what you get for buying cheap injectors?
You mean you logged IDC with the Datalogit? If so, you aren't logging what the injectors are doing - you're logging what the PFC is telling them to do.
Don't rule out the battery!
I had the exact same thing, with nistune, bigger injectors... I would get stuck in all sorts of places, then I changed the battery and got a trickle charger that sits on it every night, and the problem hasn't happened at all since then :)
Are the cables you used to relocate the battery big enough?
Yes but I've already tried a new battery? If a 720cca battery isn't going to make any difference then it doesnt seem likely that it's the battery. I used 00 gauge cable, it's plenty big :)
Are you sure that is how it logs? Why would the power fc tell the injectors to spray bugger all fuel at the start of cranking then more after it starts once I added a larger ms time? It 'should' be telling the injectors to open for 'x' amount of time immediately. If the injectors aren't doing what the pfc or in Hanaldo's case nistune, then it seems that the injectors are crap. What is your take on the whole hot start thing Lithium?
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
