Well, as much fun as I've had owning this thing, it's time to get something small and economical. So, I'm selling my Legnum, the details of which are:
Year: 1997
Make: Mitsubishi
Model: Legnum VR4
Colour: Trigger Mauve
Transmission: 5 speed manual (this is shared with the earlier Lancer Evolution models and won't give you any troubles, unlike some of the autos)
Mileage: 73xxx kms
Reg: until April 2011
Price: Around $12K
This is a prefacelift manual and I've owned it since November 2010. The car is a stockie, save for a K&N panel airfilter and rims that the previous owner had installed. The odometer reads 73xxx kms, and according to Meek Automotive, the kms haven't been dialled back much (unlike many other imports). When you see the interior of the car you'll understand that the car really is a low km example, with all plastics and fabrics in near-showroom condition. The only thing to note is the aftermarket radiator, which appears to be a cheapie off ebay. Again, this item was fitted by the previous owner and I'd be happy to help a potential buyer source an OEM radiator or to reduce the selling price to account for the radiator.
The car has rego until April 2011, and I've just put two new tyres on the front. The car has been serviced at Meek Automotive (I've got receipts) and they have replaced the gaskets and lifters and, more recently, all oils have been replaced (engine, gearbox, AYC diff, etc).
My mobile is 0458 802 345.
Cheers,
Ray
Here are some pics (I'll try and take better photos):
https://www.sau.com.au/forums/topic/375194-fs-1997-pfl-manual-legnum-vr4/
Sweet looks good.
Not exactly in the market but would be a nice upgrade to the magna :)
Was looking for one in this colour but only auto's were about.
I will give it some thought.
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
