The pro version of the power fc pro has the ignition cut on the rev limiter instead of fuel, which is generally a bit safer on the limiter
also has a launch control feature, in which you can set a max rpm that is active whilst the car isnt moving, use to be able to get about 0.8bar of boost at 3500RPM, was very good at launching the car
Datalogit- Beige box early version
Can have both for 1550 delivered
No low ballers, i know the price is a little steep, but its a pretty rare version, its what i payed for it not so long ago and with the amount of tunes i have for it and the amount ive spent on the tunes i definitely wouldn't be selling it for any less.
Cheers
Jarrod
https://www.sau.com.au/forums/topic/375341-power-fc-pro-datalogit/
bump
I tried to PM you but it failed, if you can PM me please. Anyway, I'm keen on the Datalogit. Does this include the software and hardware to get the output from my power fc? Does it allow me to tune it too? Ive got the standard R33 RB25DET Power FC. PM me man if the price of the Datalogit is the difference you're charging, ill take it.
  • 1 month later...
Hey Guys, sorry my msg box might of been full.. ive advertised the power fc on ebay now, heres the link
http://www.ebay.com.au/itm/320777089015?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Jarrod
  • 3 weeks later...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
