Hey guys,
I just ordered my flywheel and clutch. I even ordered some 660cc RC engineering injectors for my big turbo setup
The problem is that I cant justify spending over 1000 dollars on an exhaust manifold for my big turbo setup. I am going to get a gt3582r and the manifold needs to fit a lest hand drive 240sx. There are a few, cx racing has one that looks DECENT but it only can take a 38mm waste gate. I don't want the boost creep BS and would rather do it right once. STEC in japan had some good manifolds with good reviews for 500$ with 50mm waste gates, and the reviews were good. Their site is no longer up...
Long story short I have been staring at the computer for four hours to no avail.
any input on this matter would be very very appreciated. any used manifolds from people parting out rb25s would be too. I'm more than willing to get the right piece shipped to the U.S.
Thanks, John
https://www.sau.com.au/forums/topic/376012-need-help-exhaust-manifold/
go the $1000 manifold, if you get something cheap it will crack and cause you problems which either means you spend the same money getting someone to fix it in the end.
the good designs from the $1000 manifolds also help turbo response, but at the end of the day if you are the type that thinks ebay parts are great and worth the money there is nothing we can say to make you think otherwise.
Cheap
Reliable
Fast
pick two.
Cheap
Reliable
Fast
pick two.
+1, dont do a half arse job! A proper steam pipe manifold will last forever. The cheaper ones crack, and before you know it, you'll be taking it off to weld up all the cracks.
He is US, so it would be a bit more + delivery.
So closer to 1400-1500... But that's what you have to pay for a decent manifold.
A turbo capable of 370rwkw+ = need good supporting mods. A cheap manifold/gate setup is not one.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
