So i'm throwing Poncams on my R33 GTR motor, as we all know these do not require any valve train mods and give power out of the box, however from everyone's experience would it be beneficial to pair them up with cam gears then tune? Or do they already come pretty well set up as a bolt-in application?
also any suggested settings if cam gears are suggested?
p.s. motor is freshly built, running RR581 turbos, z32 mafs, etc. etc..
Many tks gents!!
always best to get adjustable cam gears, helps fine tune to the finest. since you already spent that much cash on your engine, might as well get the gears.
to get the maximum out of any cams, you will need to get them set up to a certain degree. most people i know run stock at -4degrees.
