hey guys. done a search and havent found the info im after. im after a 34 Ztune front bar side skirts and rear pods only. is there anywhere in melbourne that does them? besides jsai ive heard there extremely slow. and spoilers galore wont tell me who they buy it off so im not sure on the quality. will an aftermarket fibreglass bar be all rippled and wont line up?
if someone knows a good place that has quality bodykits let me know
cheers
https://www.sau.com.au/forums/topic/376165-r34-ztune-bodykit/
  • Replies 62
Ive got the rear pod nismo style from jsai.. Won it thru ebay bid.. and now im thinking of putting on the nismo side skirts too.. Where are goin to order your side skirts from? Wanna do group buy? Im keen for side skirts..
Edited by myRB25DETT
Or just for laughs, find the part number for the Nismo Z-Tune front bar, call up your local Nissan dealer and see if they can order it in for you.
They will either be thinking "WTF?!" is a Nismo Z-Tune front bar..?
Or they would list you a price and you'd be "WTF?!" I am not paying that!
:laugh:
Some Nissan products are actually good in price as I have bought a few parts from them.
That's is a lot for a front bar.
But you'd expect it, if it being a genuine Nismo Z-Tune Front Bar.
+ you have to paint it the colour to match your car.
Unless you buy copies and hope it all aligns and fits correctly, cause if it doesn't then you gotta spend the cash modifying it to fit.
Or at least find a company that makes good copies of it.
But if you can justify it, then go for it.
got quoted over 800 for a front bar in fibreglass is that way to much?
Sounds ok if it's a Nismo Z-Tune...
I am only familiar with R32 GTR Front Bars and I was told the prices go anywhere from $400 - $700 (Non Nismo, I think?)
The Average price for a Nismo R32 GTR Front Bar is around the $550 mark, 2nd hand.
Either way, $800+ for a copy Nismo Z-Tune Front Bar sounds better then $2500 genuine, when you cannot justify the genuine price.
+ You will need to paint it as well.
As long as the fitting is good then go for it.
yeh i didnt include shipping from syd to melb. im going ahead with the transaction hope fitment isnt to bad. i know it will need a bit (the main reason im doing the front bar is it sits higher than standard vspec bar so i can lower it more hehe) i might put up some pics :)
cheers
hey mate, this reply might be a bit late in coming .. but in my experience (and it has been suggested by others in the past i think) if you're going fiberglass, it may be a good idea to get the parts from the guy who will be fitting them, leaving them with the hassle of fitment, and someone to go and see if fitment problems start to show after. (in my case the sideskirts on the drivers side door werent fitted very well and has lost a fair bit of its paint from the door opening/closing - not too sure if i explained that too well)
anyway all the best with the bodykit!
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
