Hi all,
Up for grabs is my full GT30 high mount setup that I ran on my R33 GTR for no more than 2000km. Am selling this setup because I'm now running a set of N1 turbos and no longer need this kit. I would prefer to sell this as one complete setup with pick-up being the preferred option (for obvious reasons!)
I'm asking $3000 for the full kit that is guaranteed to fit onto your RB26, clearing strut tower, strut bars, cam covers and front drive train etc. The turbo was only run at 15 pounds and although it doesn't require it, was always idled for 1 minute prior to engine shutdown. Breakup of the prices are below, with original costs in brackets.
1. Garrett GT3076 ball bearing turbo .....$1400 ($1840)
2. Custom built tuned-length manifold with external gate mount.....$900 ($1350)
3. Mandrel bent 3" dump pipe (I have a stainless and mild steel item for you to chose from)..... $100 ($300)
4. Tial Sport waste gate ..... $350 ($455)
5. New Pod filter, air intake pipe, braided oil feed line, oil drain hose, flange plates, dump pipe clamps ..... $250
Feel free to send me a PM or 0413 893 942 if you have any queries at all.
https://www.sau.com.au/forums/topic/376750-highmount-gt3076-kit-for-rb26/
Any changes needed to fit R32 gtr? Also, why did you go back to n1s?
Piranha, I'm not too sure about how things would fit inside the R32's engine bay. There was plenty room to spare either side of the turbo in my R33. I'm pretty sure that manifold wise and so forth, everything should bolt up. One would really have to check manifold stud spacing just to be certain
I've been trying out all sorts of turbo sizes and configurations - so far it seems to be a draw between the N1's and GT30 but can only run one or the other ;) The GT30 came on a bit harder (big single style) while the N1's seem to be more linear.
Edited by tommis85
What rear housing on turbo?
Also what power were you making?
How was response rpm wise and when did it start to drop off?
The rear is .82
I was making 352hp at wheels on a very safe tune at around 1 bar. Just ran out of money at the time to be able to run turbo at it's efficiency which would have been between 18 and 20 pounds, equaling around 400hp at the wheels on a decent tune.
Response was actually good for a big turbo....little bit laggy below 3500 but once above that it ramps up hard and doesn't drop off.
Edited by tommis85
Here are some photos of the manifold's collector / flange as requested.
The flange plate itself measures 108x66.4mm while the stud spacing measures approx 86x44.5mm centre to centre.
Hope this helps but please note, I really would prefer to sell this as one full kit as complete as possible. I still have parts left over from my last sale.
Edited by tommis85
  • 2 months later...
Ray, here's a hi-res pic of the dint in the underside of one of the runners. The manifold is made from thick-walled mild steel steam pipe and I dare say the area there will be OK. I was running it like this for a couple months.
  • 1 month later...
Hi all, just letting you know that the manifold is getting fixed this week. The entire dinted runner is getting removed with a new one being put in place. Please let me know if you're interested, cheers!
  • 3 weeks later...
Hi all,
Here are some pics of the repaired manifold now ready to be mounted on a 26 out there! Dented runner has been replaced with a new bit, cleaned and repainted. Will throw in collector side studs, gasket and nuts.
Will post to anywhere in Australia as per other parts that have been sold already.
  • 3 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
