180SX Parts
Mint 180sx door trims.
centre dash console
Rear seat $100
some small random carpet bits
L&RH DOOR LATCH INSERTS $ 15
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $400 with the front cut
180sx sunroof cut
R34
POWERSTEARING PUMP $80
AUTO CONVERTER $50
AUTO STARTER MOTER $80
R32
2 door bn sideskirts good nic $100
r32 gtr roof lining
32 gtr roof cut
R32 gtr rear brakes
R32 gtr rear diff and shalfs
r32 gtr stock struts good nic
Gtr front cradle
Manual clutch pedal
R32 {4 Door}
Door Trims
Rear seats
Carpet
Climate
dash
cluster
Doors
Boot
Rear bar
Tailights
rear cradle
BN rear bar and side skirts brand new
Pick up from barossa valley or Angle Vale Area Pm here or
email [email protected]
cheers
180SX Parts
centre dash console
Rear seat $100
HANDBRAKE COVER $15
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH WIPERS
BRAKE BOSSTER
L&RH PILLAR TRIM
CA LOOM
CHAROOL CANISTER
180sx sunroof cut
R34
AUTO CONVERTER $50
R32
r32 gtr roof lining
32 gtr roof cut
R32 gtr rear brakes
Gtr front cradle
Manual clutch pedal
R32 {4 Door}
Door Trims
Rear seats
Carpet
Climate
dash
cluster
Doors
Boot
Rear bar
Tailights
rear cradle
cheers
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
