I am organising a group buy for Whiteline Skyline Sway Bars. We require a MINIMUM of 5 orders to go ahead.
Front R32, R33 and R34 GTR;
BNF27Z; 22mm ADJ AWD RRP; $265 Me; $220
Front R33 and R34 2WD ONLY!
BNF24Z; 24mm ADJ 2WD; RRP; $265 Me; $220
BNF24X; 27mm Fixed 2WD; RRP; $265 Me; $220
Rear; R33 and R34 2WD & GTR ;
BNR11Z; 20mm ADJ; RRP;$299 Me; $240
BNR11XZ; 22mm ADJ; RRP; $299 Me; $240
BNR11XXZ; 24mm ADJ; RRP; $299 Me; $240
R32 2WD
Front; BNF 28Z: 24mm Heavy Duty Blade Adjustable. RRP; $265 Me; $220
Rear; BNR 26Z: 22mm Heavy Duty Blade Adjustable. RRP; $299 Me; $240
Rear; BNR 26XZ; 24mm Heavy Duty Blade Adjustable. RRP; $299 Me; $240
Front Links; R33, R34 GTR and 2WD (Not R32 GTR or 2WD)
KLC108; Front Heavy Duty Ball Link; RRP; $180 Me; $120
Rear Links; R32, R33, R34 GTR and 2WD
KLC109; Rear Heavy Duty Ball Link; RRP; $180 Me; $120
You can order any item individually, or all of the above to make your Skyline even more of a corner devouring beast!
Delivery is not included in this price, and rather than quote a "one size fits all" cost, contact me with your postcode for an accurate shipping cost.
The average shipping cost over the last 4 Group Buys I've run has been around the $20 -$30 mark; (insurance is extra).
As I live in Faulconbridge (Blue Mountains), all those wishing to come to me are welcome otherwise, I am happy to travel a reasonable distance in the Sydney area to deliver at no cost!
This is a great saving over retail, and an excellent chance to get hold of fantastic quality components that will really improve the handling of your wagon!
To stop this from dragging on for ages, I will requre FULL payment by Monday 3rd October 2011, and delivery is should be around 2-3 weeks later; 17th October onwards (actual delivery date may be a little earlier or a little later) depending on manufacturing lead time.
Please PM me for a shipping quote BEFORE depositing any funds.
Rest assured, I will be keeping in touch through the process, and in contact with all purchasers once they're ready!
Banking Details;
Dale Laughton
ANZ Bank
BSB; 012-836
ACC; 5333-44981
When making a payment, please use your forum user name as a reference, so I can confirm payments.
So let's get cracking!
Cheers, Dale
What are the links for? I'm interested in getting a set of swaybars for r33 but not sure whether to get adjustable or fixed yet.
The links use a fully encapsulated heavy duty ball joint; basically removes all of the give in the urethane bushed style set up that are included in the Sway Bar kit.
Gives a much more direct response; but without any of the attendant noise and maintenance isses encountered with race style, aircraft (or Heim) joints.
I use these on my own car and the difference in response even on an OEM Sway Bar was incredible.
What would you recommend for a R33 GTS-T combination in front & rear swaybar size ? I was thinking of putting the 24mm adjustable up front , with the 22mm adjustable in the rear . Also with the links all way round aswell :)
Spot on I reckon; the 27mm front is probably a little too much for the street. The links just make a nice package that little bit nicer...
Looking forward to having you on board.:thumbsup:
Plus I would like front an rear links. All parts for 1996 ecr33
No problem; I can do that.:thumbsup:
Do you need delivery? If so; please PM me and I can fix you up with a postage price.
Cheers, Dale.
Dale you should get the mods to move this thread to the group buy section an delete the other one :thumbsup:
It actually is in there, but most people don't seen to look in there; I thought this might help it get a bit more traffic.:thumbsup:
Got 3 so far; if needs be I'll go ahead with that, but I'd like a couple more. Normally there's a bit of a rush in the last week.thumbsup.gif
Going to get involved?
Edited by Daleo
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
