I think there is the odd one that goes for $6k for the "rubbery" landed figure.. which basically means they are free in japan (they're scrap metal to them), but then you have to add the engineering, stamp duty, registration, etc. It all adds up to at least another $1-$2k.
They are around but who knows the condition. Some look good in the photos. Not sure who is exactly buying these cars, probably noobie p-platers. Some must have landed in the country by now? Don't hear much feedback on any of them.
mine arrives this weekend
turbo auto
sunroof,one owner 76000 log books,cruise control, grade 4 no accident`s or repairs...will owe just over $8k complied
this is about as cheap as good cefiro`s get..turbo`s anyway
the $5k cars are garbage ...scrap cars ..don`t waste your time ... get some thing decent to start with..there is some nice one`s still there
If you can get one for the equivalent of about 1500 bucks then it'll cost between 8-9k landed and registered. 1500 bucks still doesn't get you much so you have to look pretty hard. The really good ones go for alot more.
But you now have the extra bullshit that was brought in a couple of weeks ago that bits of the air conditioning have to be removed before it goes on the boat so basically add 200-300 to get it here and 400 to fix the aircon when it arrives
$9k was easy...is about 400k yen in jp, you can check the rest of the costs from the calculator at http://www.prestigemotorsport.com.au/
However, like I said the car was not in great condition...and I haven't had to pay for rego or compliance because its a race car. All other costs are the same tho
well, the problem with the brokerage fee is they do the same amount of work no matter what the price is....would you want them to check it less thoroughly because it was worth less? All the paperwork takes just as long too :)
In any case, as long as you don't expect too much from a 15yo car it can be a great deal.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
