ok so I just finally got my car running sweet just got the new exhaust on and driving it home and the turbine wheel exploded. It's a rb25 turbo was ment to be high flowed not the case as it seems. My biggest worry now is it was high mounted could the bits of wheel go back into the block and cause damage? Also I'm now in need of a new turbo any suggestions and I want it to highmount as iv already got everything set up that way and yes I have read the rb20 forum but would still like suggestions/ advice.
My mods are
3 inch exhaust
35 mm turbosmart external gate
Stainless highmount
32 gtr cooler 2.5 inch piping
Tommi fpr
Walbro fuel pump
New hd clutch
And replaced every gasket on the motor and sensors
Will be putting in 550 injectors
And I'm getting a nistune once this is sorted
Help would be very apriciated
Thanks in advance
https://www.sau.com.au/forums/topic/376958-turbine-wheel-out-the-ass/
Hi or lo mount won't make much difference as to whether any turbine fragments made it back inside. That's all due to the random acts of gas flow and whether any blades were released in the direction of the manifold flange.
Looking at the Hipergear thread, you'd be hard pressed to go past getting one of his. You'd probably be smart to try to get hold of another turbo with an OP6 housing on it, but they could hiflow yours quite successfully. ~$900 for mucho boost+flow.
I already have one welded up to suite wastegate I might check that out then sounds good I'm only chasing 220 to 240 kw anywhere close and I'll be happy. I might just take the manifold off to be safe. What about a gt30r heard these are good for a 20 or even a td05 or 6 I was leaning more towards that option Thanks for the help
Hi flowed RB25 turbo is perfect for this. They are good for 240-250rwkw.
Yep good idea
Well you could... But your only chasing 240kw. The high flow will be cheaper, As said, $900 or so.
I was just thinking about leaving some more head room incase I get over the 250 mark. I don't want to have to buy a turbo again to make more power I would like to install cams and gears later down the track to get a bit more out. I have my waste gate set to 17 psi and was thinking with a td05 I would get good power still and not loose to much response I'm not worried about lag its a 20 need lag to get good power. Also the rb turbos don't seen to suite the highmount to well very close to engine because of the flange. I would rather just do it right the first time and have it done then all I need is boost. I'm no expert I'm a metal fabricator not a mechanic so what would be my best option if I wanted to push 240 and up and please don't say buy a rb25 because it's not a option
I pulled the turbo off today and stripped it the wheel has caused exssive damage to the op6 housing gouges and dints everywhere there was a lot of burnt oil in there as well so I'm thinking a big chunk can through and that's what caused this problem as it was only on 8 psi. Can the rear housing be re machined and used as a high flow so I can sell it? Compressor wheel is fine. Iv also put in a injury for a td05H-16g6 with a 8 cm housing t3 flanged would this be a good option for both response and power?
Ok thanks for the Help mate I also did a serch on the td06l2-20g and it seems that the only difference is the turbine wheel is a few mm smaller but compressor is that same would the results be similar I'm guessing it wound run out of puff faster that's all
Edited by Bsa
