Up for grabs is an obscure (but 100% functional) piece of kit.
Includes:
* HKS F-CON V gold v3.1 ECU. (major software version differences are superficial minor updates that 99.9% of tunes dont use anyway)
* Custom-made F-CONV-to-ECR33 harness, with 2 optional switch outputs used (fuel pump relay, NVCS / cam shaft switch / solenoid)
* 3 bar (43 psi boost) MAP sensor, and IAT sensor, together with sensor harness.
* 100% english software, with hardware dongle and serial comms cable.
* Support from me, so I won't leave you in the lurch after the sale.
Features:
* 32x32 fuel / ignition maps.
* integrated self-learning target AFR map.
* more tuning tables than your Apexi PowerFC.
* ignition cut.
* double-spark (this is not a well-known feature of the HKS ECUs)
* switchable maps, so you can switch between E85 and PULP.
For more feature details, check out: http://1jzmerc.com/h...-con-v-pro-gold
I'm selling it as I bought the ECU as an extra - I have more than one - for testing purposes, and to demystify anything and everything about HKS ECUs and their variants.
It is 100% functional and confirmed working and tested on an RB25DET.
It can also work on an RB20DET or RB26DETT with minor harness / software modifications. a few more wires on the RB26, and different software settings (engine volume, injector flow rate) for AFM, or different injector pulse width for MAP tables.
The only other thing you need to do is to wire the fuel pump into full speed mode.
I will also provide _confirmed_ working maps that can either be used for RB25 AFM or 3 bar MAP sensor.
It will only need a quick 1 hour tune on the dyno to refine it to your engine / turbo / injectors / cams. That's how long it took to tune (+1 hour for setup) with the 1JZ by a tuner who has never touched a 1JZ, and never tuned a HKS ECU before.
Yes I have a 1JZ, and yes I did have an RB25 in the merc (that's another story in itself). but now it lives in the R32.
$1300 for the lot.
or $1150 without MAP + IAT sensor + sensor harness.
Photos (click for larger):
Edited by _bk_
https://www.sau.com.au/forums/topic/376978-hks-f-con-v-ecu-to-suit-rb25det/
  • 9 years later...
I need help. You have more experience and I think you could help me. I made a wiring for a fcon with Rb25det engine without the oem ecu on the page (http://1jzmerc.com/hks-faq/hardware/f-con-v-pro-gold).
You indicate in pins 17 and 19 additional commands are needed. My question is what extra should I connect on these two commands because I have given the commands 180 degrees and 10 degrees from the cas but I have no operation result.
(Cam/Crank sensor require external pull-up resistors as the sensor is optically driven).
Thank you
Edited by Kbill
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
