sorrie i made a mistake on my last post by saying they was 18".
Swap 17x9.5" dift teks + 18 off set.
In black
swap for 17" or 18" with abit lower off set looking for jap wheels or sell $1600
wheels are in sydney
sms or call for pixs 0406139299
Edited by Ands151
https://www.sau.com.au/forums/topic/377057-fs-or-swap-17x95-18-drift-teks/
also, for the 1600, does that come with better tyres than pictured?
just wondering as new can be had for around the same price(without tyres though)
<br />no worries, just offering some perspective...<br />like i said, ill grab some photos of the wheels i have tomorrow<br />
<br /><br /><br />
ok great i look forward to seeing the pixs, size and also how good are your tyres?
i got 2 brand new gt radails 235/45 r 17 tyres this week end the other 2 tyres are fair condition,
looking to swap with r33 gtr wheels or evo 5,6.7,8,9 wheels with good tyres. or something jap with less off set maybe + 35- +42 off set. 17" or 18"
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
