  • Replies 104
can i ask? "need a tune enquire within"
once upon a time.......
ok to cut a looooong story realy short
me and erin "nismogirl" raced at willowbank and i won with a 13.7, so that began the heated rivallry
next up was teh dyno. (erins choice for round 2)
1 week before the dyno day in question she was clocked at 200kw on the wheels, so was stressing as my self modded self tunned car might have been quicker down the 400 m but i doubted i would beat her on the dyno.
sooo...
i took teh arrogant approach and hyped up the day and then somehow managed to beat her, by 1kw :)
so for the salt in the wound trick, i made my sig wot it is
yip thats about it
Team Krazy:  nice...just thought u may do tuning for a living or sumthen...13.7 is pretty good tho...so do u actually tune it yaself, no dyno?
yip self tunned on teh road behind my house, under load in second and 3rd gear
me and my brother fitted the front mount and filter and serviced it
also fiddled some of the avcr settings at willowbank when i could get to higher speeds
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
