  • Replies 104
can i ask? "need a tune enquire within"
once upon a time.......
ok to cut a looooong story realy short
me and erin "nismogirl" raced at willowbank and i won with a 13.7, so that began the heated rivallry
next up was teh dyno. (erins choice for round 2)
1 week before the dyno day in question she was clocked at 200kw on the wheels, so was stressing as my self modded self tunned car might have been quicker down the 400 m but i doubted i would beat her on the dyno.
sooo...
i took teh arrogant approach and hyped up the day and then somehow managed to beat her, by 1kw :)
so for the salt in the wound trick, i made my sig wot it is
yip thats about it
Team Krazy:  nice...just thought u may do tuning for a living or sumthen...13.7 is pretty good tho...so do u actually tune it yaself, no dyno?
yip self tunned on teh road behind my house, under load in second and 3rd gear
me and my brother fitted the front mount and filter and serviced it
also fiddled some of the avcr settings at willowbank when i could get to higher speeds
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
